Can you please post pictures of what each of the power plug options looks like?
I'm looking for Australian plugs but see AT and no AU, I wonder if some of the other plugs are the same style?
Thanks.
Thanks.
I'm also in Australia and I have the same question. I recognise the other codes "US", "EU", "JP", etc, but not "AT". I know that Australia has the same power plugs as China, but none of the codes look like they mean "China" or "Australia".
Actually I just noticed that if you add a computer with an "AT" power plug to the cart, when you view the cart the power plug is shown as "AU" (which I assume means Australia). I think the label "AT" on the product pages may be just a mistake.
